White smoke comes at a steady rate after each pop while holding a steady high RPM in with no load. It also comes when revs drop from revving up. Slight smoke coming out of the right side head connection to the pipe. I also noticed that the right exhaust is cooler then the left side exhaust, gas wise. Just tested compression and I am at 147, 153 left and right. Plugs are both a black, mixture screw is set 2.25, runing pod filters. Pamco ignition, HHB PMA, mechanical timing, straight pipes with a small diameter. Valves have been set to spec via clymers manual. 78' XS 650F
