jax21
I am wanting to run a wider rear tire around a 180mm does anyone know of another swing arm that will fit or somewhere that makes or could make one?
Thats a nice looking set up. Just brainstorming here but was thinking about running a hydraulic clutch set up. So if I were to do that I could probably cut the side cover out were the sprocket is and that way not have to run the side cover spacer?
I'm thinking a offset sprocket would handle the job. A jackshaft would be for a rigid with 200mm up set up??
