osteoderm
out of the box
Great thread! Some solid work here, and I totally appreciate the effort that goes into documenting/photographing things as they move along.
One question/observation: Is this the set of triples that you ended up using?
The reason I'm asking is because that looks like a radical change (subtraction) in offset from stock. I'm using less-than-stock-offset triple clamps (TT500), and I always figured that the decreased offset would somewhat compensate for the steeper rake caused by my aggressive fork-lowering, resulting in a near-stock trail figure. Long story short, my forks are better than stock, but less than desired.
Have you worked out the changes to your trail numbers yet?
Keep up the awesome work!
I have not checked the trail, at least that I can remeber what it is. I'll check it as soon as I pull it off the rack. I believe that you are right and the rake is less than stock. The triple trees are a combination of a 1987 YZ125 lower machined for the stock XS stem and a 1989 YZ490 upper. The YZ125 and YZ490 upper trees have the same off-set, but the 490 tree has rubber mounted bars and fits the XS stem without mods. We actually have a YZ125 upper tree that we modified to fit the XS stem, but once we got a hold of the 490 tree we realized we did not need to modify it
