Punkskalar
Hugh's HandBuilt
After all the love and money spent on your XS650, it like most machine, probably has a rather severely neglected bottom end and crank... Out of sight, out of mind right?
Well not anymore. As these bikes get upwards of 45 years in age, it's likely that the bottom end could use some spring cleaning. We are very well known for our 277 Rephasing Services, but don't forget that we also build OEM Style Cranks as well.
The cranks in these old bikes can and do fail, while not in a spectacular fashion, they can still wreak havoc in your build, and have you chasing your tail as to why. Some good reading here: http://www.hughshandbuilt.com/2011/03/15/failed-cranks-properly-build-weld-xs650-crank/
Rebuilding the heart of your XS650 is critical and often the most overlook component in your build*. We can rebuild your crank to OEM Specs, with new rods and bearings as needed, trued and ready to run – or we can build a hot-rod Rephased XS650 Crank for the speed demon inside of you. Your choice, we don't discriminate.
All the details you need are located on our new and improved website, so take a look and tell us what you think. And as always, we are here to help. Thanks so much for your support folks!
Hugh
Hugh
