XS650 Progressive Shocks? Hmmm
Post the pics on here. I refuse to let Fecesbook and it's affiliates snoop on my computer.
That been said do a search for..............EDIT: After reading all Yamaha77 posts, up to #21, often condescending, there is no interaction, I won't be posting in your threads again.:umm:...................Go to the advanced search, (click on "More" in the drop box), and type those headings in the search , then click on titles only, then enter.
All the information needed unless you decide to swap a different set of forks from another Make.
That been said do a search for "Front fork upgrades" or "Minton mods" Go to the advanced search, (click on "More" in the drop box), and type those headings in the search , then ckick on titles only, then enter.
Thanks for your advice but ive been steered in the right direction by an offline convo. Had a talk with one of my grandfather's biker friends (hes very old and retired has had bikes ll his life and long before I was born) last night who is a bike genius. He advised me what to get and how to go about it.
have a great day.
No problem......................So easy to drag and drop from a folder..................Quicker and don't have my personal rights trampled on.
Good luck on the front forks, tell us what your granfathers friend advises. Maybe something different than what is known on here...... give a little back also finishes the thread
Did he mention how to address the fact those are almost an inch short?
The free spring length you have as stock is 482 mm.
I uploaded the pics for you.
I suggest you do some more research on the forum before spending any hard earned money...That said, you usually get what you pay for, especially when it comes to shocks. There are a lot of cheap options out there that are just junk. I've never been a fan of progressive springs. Race tech offers a spring rate calculator you can use to determine the proper spring rate for your weight and riding style. That's how you should buy springs. And the Race Tech emulators make a huge difference in overall fork performance.
This is very useful information and I thank you for it! We can always stand to learn something new, and I found what you said very helpful
Here is an hour's work that may make some difference. Unscrew the drain plug on bottom of the forks, drain whatever goop is left in there, flush with some light oil, drain, put the recommended amount of fork oil (I think 7 oz of 10 weight, check that) button them up and test ride, assuming that your seals are good. your suspension may only need some maintenance. Someone may have put later style 3 way adjuster tops on your forks, if so, free the adjuster up so it can be used. These machines are more for a stately progression rather than knee down thrashing.
That machine looks like someone has loved it before you, check it out thoroughly to see what improvements previous owners have done.
Here is the Progressive Spring web site,,,http://www.progressivesuspension.com/ I use PART# 771352 Springs and PART#771283 Shocks. And 11-1119 front fork springs. On the Front forks I also ad a 1" pre-load. Gary
This is just so accurate in my opinion. For a rebuild on a '74 I bought fork springs and a set of "shocks" (their term) from Mikes'XS, and honestly I think I will be putting them on craig's list shortly. Not impressed with them at all after not many miles. I have a '77 also, and put a set of Progressive Suspension shocks (only) on that one, and changed the fork oil. Much better.
Attended a RaceTech session at Barber last year. They know their stuff, are willing to help, and sell solid bits. Expensive, but I am soooo thinking about it.
Talk with Michael Morse at 650 Central. He's successfully set these bikes up to handle properly for both street and road racing and can tell you exactly what works and what doesn't. 650central.com is the url.
My bike was very mushy. Drained and flushed oil, 8 oz of 15wt. Rides nice. Maintenance is cheap. You just might think its good enuf.
