Buccaneer
Hi all,
I've been doing up and then riding around a little XS400SE, while my search for a decent XS650 went on and on, 2+ years in total. The 400 is now all done up with loads of new parts and all works well except for difficult starting; a second carb clean needed, think I missed the 'hidden' fuel feed passage for the Pilot jet (it's the Capped jet type) in my first carb boil.
BTW, for some reason the XS400 seems significantly more prone to carb issues than the 650; seems rather strange, anyone know why?!
Anyway a few weeks ago I finally dived in and bought what looked like a very nice XS650 Special, USA import ages ago, from a guy in Devon. It's on an age-related UK plate 'V-reg' which I think puts it at 1979 or 1980. It has cast wheels, factory CDI (I think, but wouldn't know for sure how to differentiate from a Pamco), a solid state finned regulator unit mounted low, black paint job, and 'Special' logo on sidepanels. The alternator rotor brushes are the 'later' type where they are both the same and neither goes to chassis / ground. Frame & Engine numbers are the same, 2F0 201 xxx. Can anyone confirm the most likely model number? XS650SG?
Knowing (owned a UK XS650SE 'US Custom' from '86 to '95 and 45,000 miles) how the charging system fails when the rotor brushes wear out, I'd checked the charging system before buying and it seemed to work. PO had it on a battery conditioner so the battery Volts were very decent to begin with (13.8 ish @ idle IIRC), but did see some rise going from idle to 2000 rpm and was satisfied with that. Rode it home 200 miles, pretty much OK (1 fuse died but replacing with spare got me back on the road with no hassle apart from the embarrassment of it dying at a roundabout). (And yes, replacement blade fusebox is here already, awaiting installation).
Anyway a week later riding it home late from work (all lights on) the lights started out a bit dim, then after 10 mins very dim, then it started missing. A sinking feeling at that time of day! I JUST got it home (semi-) safely, with creative minimisation of lights usage etc and lots of (invisible) smiling and waving at all the drivers flashing me for being poorly lit. Yes I know I KNOW I KNOW, but I don't fancy pushing this bastard 4 miles home ... or leaving it to get scratched or nicked!!!!!
So, I got & fitted new brushes, thinking that would be it (old ones still showed the limit lines, with about +1mm on the Outer, but know from past experience the brushes can fail with the limit line still showing). Anyway, NO! The battery Volts goes from 12.4 off load, to 11.8 IGN ON, to 11.9 idling and (erratically) 12.0 to 12.1 with headlight on an 2000rpm up.
So I've now checked the excellent 'Charging System Guide' on here (thanks ggggGary, nice work) and done all the checks I should have done before parting with my readies. The Rotor resistance measurement is erratic but can be seen as low as 1.3 Ohms, so, seems like the rings need a careful dress down & cleaning and, more importantly, the rotor windings have a serious short anyway.
So to the question: I need either a new, recon, or used OEM rotor in UK, (TCI compatible type with magnet). What is my best option? I already was feeling cautious about jumping straight to eBay and comments on here seem to confirm some of those 'New' ones are rubbish ... however, what about this one?: eBay item number: 331239130326. Sounds good. Then again although it does sound good I'm well aware that is all just words at this point!
Maybe look around for the best used OEM I can find, then keep fingers crossed as $200+ goes to buy some 30 year old component that can be prone to cooking? ... doesn't sound very enticing!
BTW, my initial reaction to PMA plus Pamco is I'd really rather not ... loads of money and quite a lot of faffing about to install the whole lot. But maybe I can be talked into that as the best option for a complete, long term fix.
