Howlinwolfxs
thats what i was thinking weekend, but im new to the bike scene, so i wanted to confirm.
I didn't know that but no matter, the fuel filter was an afterthought. The fact you can cause a cylinder to run by holding your hand over the carb mouth indicates that the carb is not flowing enough fuel to the cylinder and that the ignition system is fine. Most likely suspect is the enrichment circuit (choke) but there are numerous other internal circuits and orfices that can be clogged with crud and using a cleaner will take care of them all at one time. A quicker fix, would be to drain both carburetors, then re-fill the carburetors with a 50-50 mix of SeaFoam (or equivalent) cleaner and gasoline. Run that for a minute or so to get the mixture into every nook and cranny then let stand overnight and see if the problem goes away. If that doesn't fix it, you will have clean them the old fashioned way; total tear down, soaking in a cleaner, the reaming the circuits with fine wires and compressed air -- or pay someone else to do it. Start with the easy fixes first.im running it off a bottle right now, the tank is really rusty.
