Can I replace the springs without taking the whole clutch out? I’m planning on buying these along with the ebc clutch springs.
... I re-adjusted my valve clearances this evening to 006 and 012, and took the bike for a test ride. It ran noticably better at idle, and acceleration was not hampered the way it had been with the tighter tolerances. It is WAY louder and clackety, but for the performance difference, I’m fine with that...
I guess there's a trade off with increasing clearance causing more impact damage to valve stems and adjuster tips?Great!
I ran mine at 0.005" and 0.010" for a long time.
Something to try next time you're in there...
I thought running them too tight is what caused damage. ???I guess there's a trade off with increasing clearance causing more impact damage to valve stems and adjuster tips?
I read through all those links. Looks like loud and clattery will run better and preserve the bike longer, so that’s probably what I’ll run. I Might try 5 and 10 here this week to see if I can quiet her down a little. I should also note that I noticed a big difference in heat coming off the engine after my initial valve adjustment to the tighter specs. It may be wishful thinking, but I’m pretty sure that the looser 6-12 specs have remedied that problem as well. I suspect that the excessive heat may have been a contributor to my RH cover gasket leaking.
