Yes Sir Sorry about that I confess this has been a bad performance by me.Post #8 page 1 I posted a pic of my carbs that showed the different setting for each pilot screw.
Been a while and many pages later.
I have never had much carburetor problems over the years 4 - 5 times over 40 Years
.So I Tried to find electrical Problems for to Long --The proverbial " Lost in Space " .. Where one can use a different Methodology . At least when having done it many times And on an old bike with substandard wiring there are electrical problems ( Everything is a problem ) I had a weak old battery for starters .
One can measure and try. If not working try something else. The quick fix Use parallel wires and Whatnot.
And then when I found the Carburetor Problems I did not clean it Properly ( Had No compressed Air then )
And then started to adjust .and shift Jets without reading the manual. ( Could not start it on one Cylinder )
A learning curve here ..Jump in and try to fix it was not the right method. This Time
