i had to pull these connectors from the back but after a few minutes of digging through the other wires i finally got them. Just gotta wait for my blinkers to get here and then i’ll see if they work
Cosmic, someone recently suggest to paint the inside of the headlight white - there was a picture associated - it looked great - def something worth considering if you ever get to that point, made the wires look much sharper
You have work to do. I suggest you take all connections apart, (individually for a start), and untangle all the wires. Painful job, but it will pay off by giving you a lot more room in the bucket when installing the headlight it wont be putting pressure on the connections and le likely to pinch wires.
Seen this in your pic. Go through with some WD40, or kero, and wipe down all the wires and check for damage when rearranging the wiring.
I used to be intimidated by the headlight bucket wiring but after doing it a few times it’s really pretty simple and done correctly will give you plenty of room. As far as having to take everything apart to paint it, 5twins suggests using a brush so you can do it with everything just pulled aside.
