The factory spec for the '75 carb set is 3/4 ± 1/2 turn, but just as with all the other mix screw specs for the various carb sets, it is meant as an initial setting and just a starting point. From that setting, you should adjust the screws for best idle, fastest speed and smoothest running. It will probably be in that range given somewhere, but not necessarily right at 3/4. As an example, my '78 is speced at 2.25 turns but ran best at about 2 5/8 turns out.
