Tyrus
I thought maybe a few of you might be interested in this little exhaust mod. Thrush 1.75 in and out glasspacks, stock headpipes, and a bit of welding. The only modification to the bike itself was cutting off the studs that the passenger pegs bolt to, then drilling those brackets out to allow a bolt to run through to a nut welded to the mufflers. I'll let the pictures do more of the talking.
For the bend, simply took a straight piece of pipe, slit it in 4 places, and bolted up the glasspack. Tacked it while it was on the bike, and then finished it off the bike.
Better view of the slits. Screwdriver to keep the pipe centered on the headpipe.
Finished product, saw a little heat.
Yes, the right side sticks out a tad more than the left. I need to shave a bit off the mounting bolt so it pulls it in a bit more.
Figured I'd throw this idea out there! it took about half a day and it was tig welded by my father, as my welding skills are slim to none. from the headpipe back will soon be painted flat black and probably more wrap from the headpipe back to the front of the glasspack body. Turned out better than planned though! And it sounds wonderful. Cheers folks!
