You have a TX750 swingarm. They have the removable blocks so the rear wheel and axle comes off without removing a muffler.
I think maybe you replied to the wrong thread?You have a TX750 swingarm. They have the removable blocks so the rear wheel and axle comes off without removing a muffler.
That's a really good write up! Thank you!The brake components on these bikes are pretty robust. I've renovated a few and didn't need to replace any of the rubber bits, just disassemble and thoroughly clean them out. Just flushing fresh fluid through the system won't do this, you need to take it apart. What you will want to replace are the brake lines. Most of us go with one long line to replace the two originals and the splitter block they connect to. The rubber lines go soft when they get old and no amount of bleeding will give you a nice hard lever feel. It's not air in the system that does this but rather the old line expanding or swelling under pressure.
You should also go through the rear drum brake. See post #3 here .....
https://www.xs650.com/threads/how-difficult-is-it-to-replace-the-rear-drum-brakes.25632/
@5twins - Do you have a good source for the 1 piece front brake line?Most of us go with one long line to replace the two originals and the splitter block they connect to.
Attached garage? Consider plumbing it for water and drain whether you use it or not. Consider 220AC also. Cheap to do those in the build end, tough/expensive afterwards. Good luck.Day 22
I . My wife and I are in the middle of building a new house and hope to be moving in the spring where I'll move my shop indoors to the basement where I'll have heat and a/c. Forecast says there's come warmer weather coming our way for the next few days so I hope to get a little more done on it.
Come on springtime!
Actually we’re downsizing. I’m tired of mowing and I want to retire. We’re building a 3 bdr ranch and I’m taking the basement for my shenanigans. I put a big door in the basement so I can get my stuff in and out. I’ll have a heated and cooled space year round!Attached garage? Consider plumbing it for water and drain whether you use it or not. Consider 220AC also. Cheap to do those in the build end, tough/expensive afterwards. Good luck.
We downsized in a major way 5 years ago. my shop is the third bay in the garage. Basement is mancave/grandkids play room. I decided to concentrate tools and projects to one area. My basement does open up to the back yard 6 steps up to my fire pit. The garage stays warm enough, above 40F and for projects with a small electric heater keeps it in the low 50s. Choices. Enjoy and embrace your downsizing. I assume all your facilities are on the main floor. CongratulationsActually we’re downsizing. I’m tired of mowing and I want to retire. We’re building a 3 bdr ranch and I’m taking the basement for my shenanigans. I put a big door in the basement so I can get my stuff in and out. I’ll have a heated and cooled space year round!
Blank slate is fun. Enjoy the planning and build out. Some thoughts. I wired all corners for speakers, 12 gauge, and CAT6 data cable, never sure why or when you will need it. My floor was not completely flat and level and I only noticed that after the floor installer laid the composite tiles down. If you are framing in any features, measure down from the ceiling, not up from the floor. Figure out how much light you need, then add 20 or 25%.@Kevin Werner Nice! Looks really good!
Yep, it's a ranch we're building with a nice big walkout downstairs. I'll have my own crapper, lots of room for my projects, and I can mow it in less than an hour. I'm happy!
You had me at "my own crapper"!@Kevin Werner Nice! Looks really good!
At my age that's important!You had me at "my own crapper"!
Indeed!At my age that's important!
Nice!@Kevin Werner Nice! Looks really good!
Money well spent. Best thing I did in my shop.I'll have my own crapper
You think so now just wait.lots of room for my projects,
