Got job of building set of XS650C carbs.
After receiving the bits i had a closer look at them and found a few things i did not like;
first off these are parts from a keyster kit; needle came with Y5.5 on it , i queried this and was told that is the norm now? i was looking for a "4M" needle id?
Next the float needle kit did not have the viton tipped float jet, just the plain steel one. i thought these became obsolete years ago? The emulsifier tubes i received have holes in it that are a different size to the original item i am replacing, the quality of the tube was naff in otherways. i found burrs and a rough finish inside, is this the norm for keyster kits, is that all they have on offer these days?
My other queries are to do with the rebuild; i could not get the emulsifier tube to stay in place, the o ring stopped it seating. This meant that the float bowl was jamming it into position, which could mean i get a leak round the bowl gasket. Is this usual to find difficulty seating the tube?
Do you people think it vital to replace the choke shaft seals , because i really do not want to remove the shaft at this stage?
Finally can i expect good results from these carbs , not super performance , just to start, idle and good pickup
