Jdove
XS650 New Member
HI all,
Bought 1st xs650 trying to get it road ready. It start easily cold (no choke) and idles well 1100 rpms, until warm and then shuts off. When I continue to kick it, it back fires out the left carb and pops the carb out of the boot. This has now happened twice in a row.
Since I got it approx month ago I have put on coil, wires, plugs, pamco ignition, pma, carb boots. I have cleaned the carbs, set float height. I am running pods with straight pipes. Jets are 135 main and 42.5 pilot. Mix screw is 2.5 turns.
I checked/adjusted cam chain, valves, timing, bench synced the cabs with a piece of paper to get it going. Fixed small tear in left diaphram. Checked for air leaks around boots and throttle with quick start, no significant an't change in idle.
Tried to set idle/mix with DCM however it will not run on one cylinder. Also it will not run long or reliably to sync with monometer yet. I am thinking I am running rich (plugs are black). It is running hotter on the right side. I am wondering what to change/check next.
Any advise would be appreciated.
ThanKS
JDove
ThanKS
JDove
