bikerjack
First of all, thanks to all who have helped out with the technical aspects of the XS. My 77 was found sunk down in the mud, past the bottom of the frame and SOOOO many dirt dobber nests on/in it. Motor out of the frame and the frame looks good. And yes, checked the bottom of the frame. No cracks or splits from sitting in the mud. Within 3 hours, heads and cylinders removed. Not cracking into the lower end cause everything in there looks brand new, from a flashlight point of view. Valves are not seating and have so much carbon on them. Cylinder walls look smooth except for a thin line of faint roughness in left side. Not enough to redo the cylinders. Top of pistons are carboned up pretty bad. Wrist pins are super tight. So, after a valve tool is acquired, I will be able to get a better look at that part. Will put pics up soon.
