Thanks guys this is where I am, I pulled the side cover looked at what I believe is the so called oil pump, beats me how it works. Let me make sure we are talking the same thing it looks like it drives the tac on the side cover and when you pull it apart it has what looks like a star with a little arrow. If that's right I pulled the parts cleaned it and the tunnel or tube next to it. No blockages where found. Next up the small nut the oil pipe screws into thanks for the heads up on not over tightening. Also I was having trouble putting the side cover back on, looked like the kick start was keeping it from closing. I might of pulled it out a little when I removed the case is there a trick to this. Thanks again guys your helping me a lot.
