cmills83
Hello
Just picked up a '83 Xs650 basket case.
I am looking to build a vintage streetfighter/cafe but I notice the later years are generally setup more as choppers/bobbers so I have some parts interchangeability questions.
1. Rear setup:
The rear rim I have is a 16" Im assuming stock and the front is a 19". Id like to atleast have a 17 or 18 on back. I also need a swingarm and shocks, are all xs650 years interchangeable with the '83? My idea is to get a 17" then a swingarm and shocks off an older model so the back doesnt sit as low.
2. Forks and triple clamp:
What years are interchangeable? I plan on using stock forks and having them cut 1-2" or just sliding up in the triple clamp.
3. Engine:
Im not sure if the engine I have is good, Ill test in the next few weeks, if not what engines are interchangeable with the '83? By interchangeable I mean direct bolt in no custom mounts.
4. Tank:
It appears the older model tanks don't taper as much (looking straight down) are these a direct bolt in on the '83 frame?
Ok I think thats it, other than that I should be able to get everything else to work I just wanted to check interchangeability before starting to order parts.
1. Rear setup:
3. Engine:
4. Tank:
