Cheftay, there are 2 sets bushings in the camshaft. What your link shows is the outer bushing, or labyrinth seal, which is there to retain grease. The inner bushing is a separate part; that's the one that supports the ignition rod. Since you can easily remove the labyrinth seals do so and check their fitment on the uninstalled rod, then slide the rod in part way and check resistance on the inner bushings one at a time to locate the bind. If everything moves smoothly when individually inspected, you'll know the bind is due either to a cocked bushing or to runout in the advance rod. Don't try to cure the disease before you've diagnosed it!
