http://www.xs650.com/threads/1981-650-miscellaneous-parts.57338/#post-645141
If I was you before buying anything for the TCI I would run through the resistance checks of the system in the manual. If you don't have a manual go to the tech section and download that one or biker.net has one as well. If it is the TCI box bad you can buy the four diodes on ebay for cheap and/ or resolder the joints. I actually have some of the diodes if you want to get some from me, but still do the resistance check and read the ohms on the tci box. I almost bet that may be your problem.
If everything checks out then check your ignition coils next. If it is the stock coil it almost should be replaced anyways, but check the end caps too that plug into the spark plug for corrosion by pulling them off the wire. It is also likely they may be loose in the first place too.
