JAX71224
jax71224
AAAANNNND about condensers ,if you observe sparks from points while idling and points are good as you can get them, try new condensers, It will prolong points life and run better.
XS leo…..I'm sure someone has. I just don't really see the point. With the points, you're still limited to about 4 ohms.... which means about 3 amps of power for making sparks. Some coils use a higher output secondary, but 3 amps is still your limiting factor. You'd have to go electronic iggy that can use around a 2 ohm coil for a hotter spark. 2 ohms gives you about 6 amps of juice to make sparks.
Yeah... there's a whole lot more to it than my simple explanation.Lower impedance coils discharge the condensers faster. The size of the condensers determines the amount of energy available to discharge across the primary winding in the coil. A single set of points with one condenser is probably not enough to saturate the primary reducing the output spark. A larger cap on a single points set would work at the expense of greater arcing across the points shortening the life of the contacts.
hello all, I was reading post after post about what coils to use with a points set up, I have a 72 xs650 and a 69 xs1 (and yes photos of my bikes to come soon) they are both hard ridden bobbers, anyways, I have a huge box of parts and many of my coils are white and many are black... heres the reason I ask, both th bikes have points but the 69 has always had a wird misfire and sometimes a complete cutout (no spark)on one cyl. and Ive tried switching coil after coil to solve the problem and it always seems to work for a bit but eventualy the problem resurfaces again, maybe related to the coil maybe not, but Im wondering if the black ones are for electronic ignition, and the whites are for the points, let me know what you guys know thanks, or even better if there is a replacement coil to use with points that works "very well" let me know about those,
