SteveP
Hi all
I've been working through the masses of amazing information contained within this site. I haven't so far needed to start any post because I've always found what I needed by searching old threads on this site.
I purchased a non running import into the UK around nine months ago. It's a 1974 TX650A that seemed to have bounced down the road, and was then left in a barn for twenty years. It's got 20000 miles on the clock, which seems to be genuine. It was sold with the engine seized.
I'm happy rebuilding engines. I'm just struggling with what is normal for an XS650.
I had assumed that the engine was seized because the rings had stuck to the piston bores. When I lifted the head I found parts of one exhaust valve on top of the wrecked piston. And the other exhaust valve stuck open.
The valve seat seems to have taken a bit of a battering.
The rocker arm faces don't seem bad, but the tappit adjuster screw ends look Damaged.
I'm not sure if the valve adjustment or possibly the ignition timing was set wrong, or the advance mechanism was jammed.
Has anyone any ideas what could have caused this?
Has anyone any advice on what I should be replacing? Possibly exhaust valves and springs. Tappit adjuster screws.
I don't think that I can get away with lapping the valve. Can I get the seat recut, or will this mess up the geometry? Should I try to get a new valve seat? This was common enough with triumphs and Nortons when unleaded fuel was introduced. Should I just source another head?
