I guess HD wants so much to do a V-Rod because you must do the following,
Place the front wheel in a chock to hold the bike upright
Remove the faux tank/airbox cover
Remove the airbox from the throttle bodies
Remove the breather lines from the cam covers
Place a floor jack beneath the engine raise to contact the sump
Disconnect the top front engine mount, engine pivots on the swingarm
Lower the front of the engine, necessary to remove the cam covers
Remove the coil packs and spark plugs
Remove the cam covers
Remove the stator cover to be able to rotate the engine
Rotate the engine to the proper spots to gage clearance and record it
If any need adjustment remove the cam sprockets and slide them off the cams
Remove the particular cam, change the shim and reassemble
Recheck clearances to verify and put everything back in reverse order
