So this may be a little redundant but this topic really helped me out.
My bike: 1977 xs650D, bs38 carbs.
PROBLEM:
My bike hesitates to come back to a normal idle after hitting the throttle and sometimes the idle will stay high, forcing me to constantly adjust the idle screw. I determined that the
throttle shaft seals went bad(sprayed a little carb cleaner at them with the bike running and the idle went crazy)
SOLUTION:
Replace the throttle shaft seals(4) and also the screws(4) holding the plates to the throttle shafts.
From McMaster Carr I ordered:
A pack of 50: Double-seal Viton(r) Fluoroelastomer O-ring (1/16" x 5/16" x 7/16" AS568A-011) which is part number
6540K121 on their
website.
And
A pack of 100: 18-8 Stainless steel Metric Oval Head Phillip Machine Screw, M3 Size, 8mm Length, .5mm Pitch (part number
90258A178)
I have read that the OEM part is the only way to go with these seals but McMaster is located nearby and if it works out i'll be riding with a normal idle in a couple of days. I will relay the results by this weekend (5-12-12).
The o-rings from McMaster, as you've probably already read, are an offset to the Yamaha OEM part # 256-14997-00-00. It took a lot of searching for me to find this information so I just wanted to try to sum it up for anyone else looking for this solution.
As i've stated, I have a very large quantity of these parts now and would be more than happy to share with anyone in need of them!
