At the drag strip? Yes, you'll most likely notice a difference. Out on the street? Maybe.... but I doubt it.Just wonder what the Yamaha gurus think about whether or not this will have a negative effect on performance.
If you were being fussy a turn a short aluminum collar to match the carb intake ID then bevel back any sharp edge with knife or a rotary cutting tool.
The float pin is still available from Yamaha and I recommend using it .....
https://www.partzilla.com/product/y...?ref=dbcca4a3eda2a91a3015a16385a35f1bb2c177de
I just got one of those aftermarket replacements and it doesn't fit very well. It's tight going through the float so will probably cause binding. When you install the pin, you don't need or want to drive it all the way in. Just tap it in enough so the other end is flush with the outside of it's post .....
That will leave the end with the head looking something like this, which is fine .....
If you have the brass floats, you're using the wrong setting on them. 22mm is the setting for the plastic floats. The brass float spec is 27.3mm ± .5mm.
I don't have a bowl lying around to check, but I believe the bowl was designed so the pin won't come out of the towers with it in place.Doesn't really matter since it can't really get out with the wall of the float bowl restricting it's lateral movement. And thanks for the link. You're a lifesaver!
Yes, brass floats set at 22mm would result in a very high fuel level. It might not even run like that, just leak fuel all over the place, lol. And if it did run, it would probably be very rich.
I'd say your chances are more than a little bit better than 1 in 10 .maybe I've got a 1 in 10 chance of getting this bike running...
For one thing this group will not quit if you don't .
For another thing you'll find that for every question answered another appears.
It's a process, a true mindfuck.
In the end it's all about the ride (and how you got there)
Teach what you learn
On butterflies with everything assembled on the throttle shafts (in correct order ) leave the butterfly screws slightly loose. idle screw backed off. open throttle a bit, and allow to snap shut a few times (it should move freely and "snap" shut, this should get everything into correct position now tighten screws, repeat open, snap, making sure butterflies close fully and smartly.
Easy enough to mix up assembly order, several similar but not identical parts between the two carbs.
Bent throttle shafts can happen, they are just chrome plated brass, and softer than you might expect.
The butterflies are kinda fragile being brass, the edges are sharp, precisely angled, and need to stay that way. Never polish a butterfly on a buffing wheel.
Yes, I just lightly polish the butterfly plates by hand with Mothers or Blue Magic, and only lightly clean/polish the edges. Since the plates aren't completely vertical when closed, the top and bottom edges are beveled slightly to form-fit into the bore better. Make sure you install them oriented correctly. You want to see the number on the plate upright and below the butterfly shaft .....
