xsPete
G'day,
I'm thinking about running a single light for neutral mounted separate to the speedo.
My vast knowledge of what an LED and what a Resister is comes from about an hour on google last night.
So from what I can gather I need to know;
The Volts I'm using, I'm not sure on this whether to use the 12V which is the battery or what the bike will be putting out when It's finally running.
The mA that should pass through the resistor, how does 20mA sound (0.020Amps)
From what I can gather this is used to calculate what resistor to get.
So if the LED had a Forward Voltage (fV) of say 3.4 for argument sake.
Then to calculate the resistor (R), it goes,
R = (V-fV)/mA
R = (12-34)/0.20= 430 ohm resistor
So what voltage should I calculate it off &
is the mA something I'd get the info off the LED to have pass through it.
R = (V-fV)/mA
