Miss stayed on the same side.I will switch wires and see what come of it. The carbs never skipped a beat with other ignition but I did change out the needles back to original needles. Ill be back.
When I purchased the bike the compression was 120 per side. New head gasket installed. Im hoping not low compression.Ok.....progress....that indicates something amiss in the carb or low compression on the R side
Bike is running on both cylinders super happy. But now the bike is reving but not coming back down as it use too. It has BS34s on it and jetted to compensate for the small air filters and pipes with now baffles.When I purchased the bike the compression was 120 per side. New head gasket installed. Im hoping not low compression.
I borrowed my synchronizer to a friend and he never returned it. I will make one tomorrow. Super happy and very appreciative of all of the knowledge that was shared. I have over 300 hours in this build and a hundreth of that for road time. Thank you ALL!More progress. I'm guessing here, but perhaps now it's running on both cylinders, so the previous idle adjustment is now too high. So, see if it will adjust down with the throttle stop screw.
Might be good, once that's done, to re synchronize them too
I dont think its from idle screw more hanging at a higher rpm than drops to idleMore progress. I'm guessing here, but perhaps now it's running on both cylinders, so the previous idle adjustment is now too high. So, see if it will adjust down with the throttle stop screw.
Took for a ride. Hanging idle and here are the plugs.You commented "hoping" the compression was good after recent overhaul. Compressions tests are easy and fast. Most troubleshooting is eliminating maybes................
Ran like shit. Wouldnt idle.Took for a ride. Hanging idle and here are the plugs.
I also only have a kick start.Either side of the engine has no compression at all 30Lbs
I need to retract last 3 posts the compression tester dont even read a lb. on a lawn mower engine. Might be junk.oil in cylinders did not make a change.
Also after setting float height. When turn fuel back on i have to tap on carbs to get the fuel to stop running out of the carbs. I dont think I have the best carbs cheaper not cheap buy off of ebay.I need to retract last 3 posts the compression tester dont even read a lb. on a lawn mower engine. Might be junk.
I also have the jet kit from mikesxs in the carbs. I am running at this time the biggest main and idle jet they had in the kit. Odd though when I re measured the floats is when the carbs acted up when I ran them before and no adjustment to the floats they returned back to idle perfectly.Also after setting float height. When turn fuel back on i have to tap on carbs to get the fuel to stop running out of the carbs. I dont think I have the best carbs cheaper not cheap buy off of ebay.
Sounds like a float/float valve issue in the carbs. Needs further investigation. New parts may be required.Also after setting float height. When turn fuel back on i have to tap on carbs to get the fuel to stop running out of the carbs. I dont think I have the best carbs cheaper not cheap buy off of ebay.
