Hello Members,
The clutch is a multi-plate one with alternating steel and friction plates. These friction plates are turned by the clutch housing. The tabs on the outside edge of each friction plate fit between the fingers on the clutch housing. The steel plates are spline on their inner edges. These splines engage the splines of the clutch hub in the center of the clutch. The hub is in turn spline to the transmission drive-shaft. The springs of the clutch spring plate press the steel and friction plates together to engage the clutch. The power of the engine is transferred from the primary opinion to the clutch housing, which turns the hub through the clutch plates. The hub turns the transmission. To disengage the clutch, a rod pushes through the center of the hollow drive-shaft and forces the clutch spring plate away from the clutch plates. The plates are separated by rippled circular springs that act on the spline teeth of the steel plates. Without them the clutch would drag when the lever was pulled, even though properly adjusted.
Best Regards,
Anthony Martello
xkglow.com
Posted via Mobile
