Popping on decel is usually a lean indicator. If you've changed things like exhaust and air filters without re-jetting, that could be the cause. Or, the pilot circuit on your carbs may be getting plugged or partially plugged. Another cause could be an air leak around the carb mounts or a leak at one of the exhaust connections.
