Stator is "probably" fine, cheap meters have tough time with low ohm readings. probably more important they are all identical and there are no shorts.
...#3....OK Lets revisit this one; with the engine running and all connectors plugged in take your jumper with one end grounded to the engine and clip it to the brush with the green wire. Watch your voltage with the volt meter, see if it climbs above 14 volts at about 3000 rpm. If it does your fault probably lies with the regulator or a break in the green wire.
Also ohm your stator again check all the leads against a ground, you should get no reading, it should be open circuit to ground.
Thanks gggGary! Great Guide, I know squat about this stuff but the guide was very helpful, thanks again for doing that.
Ah, now i get it. Clip it to the metal part of the brush that sits in the brush holder, next to green wire on stator. Repeat rev test, note results. I'll do this in the morning (kids asleep).
OK will do. Is a "no reading" a zero "0" on a digital multi-meter? I ask b/c sometimes i get a reading that looks like a backwards "L" and "o", or something like that. Is this Infinity? I'll look for my MM Manual
