gregoryp
I was hoping someone could point out my mistake. I did the rear wheel using the Fong Bros. thread with no problem. I used the same technique on my front wheel, except it has 64 spokes. I inserted the top spokes first, then found the 6:28 location and inserted the bottom spokes starting there. Should I have started two holes over instead at 6:26? As far as I can tell the pattern is correct, but my outer spokes seem to be to short and my inner ones seem to be to long. Each inner and outer have two lengths, so I put the shorter one on the inside of the angle made with the hub and the longer one to the outside of the angle with the hub, if that makes sense. So if you are looking at the wheel and the spokes are going in the CW direction the short one is to the right and the long one is to the left. I've attached some pictures of the before and after any ideas?
