CalAl
I bought a set of adjustable compression damping valves at mikesxs.com - turns out early '77 D model 35mm forks have different (earlier type) damper rods than other '77-84 forks. Can anyone tell me how to fit these valves to the smaller diameter top ends of my dampers? Not included in mikes instructions and apparently he doesn't know.
Thanks
Thanks
The holes you drill will scare you.
I wish I had used an endmill in my drill press. It would have made cleaner, more accurate cuts. As I recall you drill the holes out to 5/16th, add two more and open up the holes on the top of the rod. You will not be able to change it back. You'll be shopping for a used set of forks. The ones I bought from "3M" sit right on top of the damper rod without a shim or spacer required. In the instructions it lists some models that require a shim, but they way I read it, it did not apply to the 650's. All said and done, I'm more that happy with the results.
