The ones that clamp the upper tree to the forks tubes? 5.8 to 9 ft/lbs
The big bolt that holds the upper tree down? 30.4 to 47 ft/lbs
The cap that holds the springs? The only reference I find is 900 inch/lbs, that seems a bit high. That's 75 ft/lbs. I just snug them up good. When you tighten the upper tree clamp bolts those caps won't loosen.
