Here.... couldn't recall for sure so I just pulled that gear to have a look. It's a slot for a pin that sets in the crank. Not sure what year this motor is or if they're all the same....
BINGO! Thats what it was looking like to me. My engine is a 447 out of a 1975. Don't know that you heard my whole story but I have been running a secondary engine I picked up years ago but want to put the original back in the bike - totally rebuilt. Long story short I keep running up against data breaches and deletions in all my manuals etc. No where have I been able to find a pic with that damn pin displayed. Thanks a million Jim.Here.... couldn't recall for sure so I just pulled that gear to have a look. It's a slot for a pin that sets in the crank. Not sure what year this motor is or if they're all the same....
Did you get the pin? Chances are I may have one if you’re stuck. Lmk. I’m in Oakville. Or Jim’s drill bit trick.OK, I'm told there isn't one in Canada. But $21.95 CAD from eBay plus 2 weeks waiting and we're back on track. I know I'll find mine in all my stuff now that I've got one coming. Thanks again. Thank god for the Forum.
Ya, I did get one on eBay cheap. Plus, my local guy has a straight Woodruff Key for the drive gear for $8.00. If the dowel from eBay isn't right or my experimenting with Jim's drill bit exercise doesn't work out I'll give you call. Oakville ain't that far. Thanks.Did you get the pin? Chances are I may have one if you’re stuck. Lmk. I’m in Oakville. Or Jim’s drill bet trick.
Never heard that beforeI just remembered something I read a few yrs ago and never followed up on. Just tested it and sumbich if it ain't true......
Modern drill bit tech heats and tempers the flutes and the shank at different tempers.
Grabbed a bit and a file and sumbich.... that's true. Ran a file across the flutes up at the tip and no way in hell could I get it to bite. Went to the shank on the other end and the file easily bit into it.
So.... a correct size bit, cut off at the shank will work just fine... no torch needed.
Yeah, I'd forgot all about it. Give it a try Jan...Never heard that before
Cheap bits and expensive bits alike?I just remembered something I read a few yrs ago and never followed up on. Just tested it and sumbich if it ain't true......
mine are all mixed together Marty, so I can't say.Cheap bits and expensive bits alike?
