Yes, this is my favorite torque chart because the values are given in ranges. Most of the other years give single values and that's no good for things like the axles and swingarm pivot shaft. With the axles, the chances are slim to none that the cotter pin holes are going to be aligned when you reach that single value spec. I never torqued my axles, just made them "good 'n tight", but once I found these range specs, I did check them. I made them my usual tightness then checked to see if they at least met the minimum value of their spec range, and they did. So, I don't actually know how tight they are, but they do meet the minimum spec so I'm happy.
On the other part I mentioned, the swingarm pivot bolt, it's also nice to have a range. I start at the minimum (about 36) and tighten the nut a few pounds more at a time until the bare arm just drops slowly under it's own weight. On the TX750 arms I have on both my 650s, that happened around 42 to 45 ft/lbs.
Since I anti-seize all my fasteners and I know you should use less torque on lubed ones, I usually stick to near or at the minimum value in the ranges given.
There are a couple values in the chart I stray from. I make the large acorn head nuts 28 to 30 ft/lbs and the front sprocket nut 94 ft/lbs.
