The xs750's with the standard, as opposed to the leading axle forks are a plug 'n' play if you can find a setup on eBay.....'course will probably need rebuilding on the master and caliper. Mikesxs sells the setup iirc. You'll need the dual output brake line junction too of course. I was toying with the idea a few years ago and put a rotor on the left side to see what the feel would be like, extra weight and gyro effect......stayed with the stock single.....
