So I've had my bike running for a few years but it has always had trouble doing more than 60mph. I just tore into the top end because I was ruining plugs on the left side really bad so I thought my rings were shot. that side was oily and the rings might be bad but the cylinder walls seem fine. There was quite a bit of oil in the head. I've never done a top end before so I don't really know what i'm looking at. Also I'm thinking my carbs have been set up the wrong way the entire time and thats was causing my 60mph top speed.? I'm going to have my carbs sonic cleaned and all new internals and want to know what settings you have for your vm34's. Also some ideas on my top speed issue. '79 with 2into1 mac exhaust no baffles and a pamco are the only mods. Also When I was doing my top speed it sounded like it started missing and not sure what that is a symptom of. maybe my advance is messed up? A little help would be nice. Trying to get it dialed in for bike week in a couple months.
Main Jet:
Pilot Jet:
Needle:
Needle Position:
Mix screw: In turns out.
Main Jet:
Pilot Jet:
Needle:
Needle Position:
