Help with Dual Disk Master Cyl Please!!!???!!!
cool hand luke
Central Coast, Australia
Hi guys
So I'm up to getting my front brakes dialled in, and need to find myself a master cylinder. Can someone please help me out with identifying what type and size brakes these are and advise me what size Master Cyl they are running if they have the same brakes?
My bikes a bit of a swap meet special so I don't have a definite year to run off.
Its a dual disk setup too.
Thanks in advance to the XS brains trust :thumbsup:
Here is what I'm working with:
From vintagebrake (AKA 650 Central)
http://www.vintagebrake.com/
While attending Vintage Days West, and thoroughly enjoying it, I was reminded that many of the people I had occasion to talk to, lacked an understanding of the importance of master cylinder to wheel cylinder ratios. This critical ratio is of paramount importance in determining "feel". It has been my experience that there is a "sweet spot" in the range. I like ratios in the 27:1 range-2 finger power brakes, feeling some line and/or caliper flex. 23:1 is at the other end of the spectrum-firm. Ratios lower than 20:1 can result a feel so "wooden" as to have a toggle switch effect: nothing happens until the wheel locks. Disc and wheel diameters must be taken into consideration. A 10 inch disc working against an 19" wheel just doesn't have the leverage ratio that a 13 inch disc working a 17" wheel does. The hand lever ratio counts too: witness the adjustable master cylinders from Lockheed and Brembo.
A case in point: I had a complaint from a racer about Ferodo CP901- a compound renown for its great feel. His comment was that they worked poorly until the wheel locked. He had been thrown on the ground twice. Intrigued, I inquired as to the application. "Yamaha RD350" he replied. A red flag went up. CP901 was not available for the 48mm Yamaha caliper. I asked "How that could that be?" He had up-graded his braking system with the 41mm Lockheed unit, but was unaware that a master cylinder change was in order. A stock RD 350 has an already poor ratio of 18.3 :1, and with Lockheed, became an unhealthy 13.3 :1. The "sweet spot" formula said a change to a 11 or 12mm master cylinder was in order: my personal preference and recommendation would have been an 11mm. He was able to switch to a 1/2" , and although not ideal, he was keeping the rubber side down.
For 2 piston opposed calipers, I like ratios in the 27:1 range, feeling some line and caliper flex. For a firmer lever, use 23:1. I think ratios lower than 23:1 produce a lever feel so "wooden" as to have little, if any feel. Combine "low" leverage ratios with sticky pads, and unpredictable lockup is the result. The high effort required at the lever also results in undesired input to the bars. Single piston calipers are much happier in the 14:1 to 12:1 range. Disc and wheel diameters, as well as hand lever ratios, must be considered.
Front Master Cylinder to Wheel Cylinder
Ratio Chart
So somewhere around a stock late model 14mm MC or the bazilion chinese will-fits on fleabay. should work well.
Looks like you have a bit of a mismatch going there, The late model rotor 77-83 (as shown) has a different offset than the early rotors 73-76 that were originally used with the the fork and calipers you have. Might work with spacers? , just a heads up.
thanks gggGary. I havnt really played with an XS like i am now. So its confusing after buying a bike in parts, slowly understanding what i have and what will work. And that there are so many different models of XS to decipher haha and also the slim pickings of parts here in Australia
But many thanks!
Its greatly appreciated!
The early two piston calipers used a 16mm MC with a single disk. It seems that a two disk setup (4 piston) would be perfect with the 16mm MC.
Tom
