I think the question you need to answer is how thick is that step that needs to be machined off. Thicker than a fiber plate?
Something else you may want to make note of is the steel plate that is used as that bottom damper plate is a little thicker than all the others. Spec on it is 1.6mm, the rest are 1.4mm. It is actually the steel plate used in the early '70-'73 clutches.
