Seller's Description
Pure custom 1934 Crocker speedway racer tribute bike, built around a 1997 Suzuki LS650 motor. Completely handmade frame, tank, forks, jackshaft arrangement, handlebars, etc. Rear hub is a front dual leading shoe from an early Honda CB350, adapted to have a sprocket. Front forks are a damn close copy of the 1934 Crocker forks, this uses a single spring reverse springer fork. Wiring and cables are run through frame. Hand made clutch perch and lever, leather hand grips, hand made internal throttle. Microswitch start and kill switch. Manual compression release. Electrics concealed in faux generator and under battery. Electric start. Old pickup turn signal adapted to LED with original bullseye lens. Tail/brake light concealed under rear fender. What isnt nickle plated is painted Viper red. Yes, it runs and no, it’s not very comfortable. Speedway front 23" wheel and tire from an old XL500. Rear 21" wheel and tire. Build thread with build details is here:
https://www.advrider.com/f/threads/just-another-savage-speedway-build-nothing-to-see-here.1429415/ Located in Central Wisconsin. Will assist your shipper to get it to you. Comes with Vermont transferable registration
