Ha! 2M and I are on the same track.
I think you should repair and keep your original frame, it’s your number matching, and there is no stigma with repairing a break. I think it’s not so much a matter of abusing it in your youth, that caused the break. I believe it was just early in the learning curve for Japanese motorcycle manufacturing. Nowadays the frame would use thicker tubing , and computers to calculate stress points. I read an article about early frame development for the Norton Commando, they kept breaking up by the steering head. One of the engineers suggested a small triangular gusset and bingo! Problem solved.
As Jim stated, I think ideally, replace the entire tube. However if you choose to v out the crack and weld it, you will need to reinforce the entire area to prevent it from breaking again. I have repaired many broken truck and trailer frames in my youth as a fleet garage welder, and the formula was always the same, weld the crack, plate over it, reinforce it with gussets if it was near an intersection with an adjoining frame.
View attachment 129393 View attachment 129394 View attachment 129395
