Slow and steady wins the race. My thoughts exactly.
Alex Hollings lays out the hypersonic weapons race as it stands today.
I watched that video and it is very good -
but - there is an important detail which may mislead some folks.
The speed of sound (Mach = 1.0) varies a lot from about 761 mph at sea level to less than 660 mph at say....50-65,000 ft and then it increases up to about 155,0000 ft. The actual relationship between Mach number and speed depends on air temperature and density - both of which
generally fall the higher you go - but then the radiation of the sun begins to heat the air molecules even as air density continues to drop.
So, the actual speed variation with Mach number is not at all simple but rather, it strongly depends on the local atmospheric conditions (see the table below).
Thus, translating a Mach number to a speed in mph or km/hr is not simple and may be rather misleading.
For those reasons, the speed of aircraft or missiles travelling at supersonic speeds are seldom quoted in knots, mph etc. but rather, they use the local Mach number as a measure of speed because it is the effects of
compressibility (i.e. the Mach effect) and not the airspeed - that affect how they fly, manoeuver and their stability, and so-on.
That is why early research into supersonic flight was carried out at high altitude - ground speeds were lower to get a certain Mach number - but then if the aircraft became uncontrollable (as many did), the pilot could recover if he could hang-in there until the aircraft was at a lower altitude and the Mach number had decreased.
Anyhow - as with so much these days, it appears that there is a lot of Chinese and Russian propaganda associated with this whole topic and it may even involve a certain...shall we say,
economy with the truth....(can you say....
Olympics?).
