pictures say about 90% of it. This is on an 80 but prolly the same all years. Switch was stuck but a
"good to do" maintenance on any old bike, you want full volts to the coil....
In spite of the small size, those screws fit a #2 (or JIS #2) screwdriver best. Polish don't sandpaper contacts. grease with dielectric silicone or 2M's contact lubricant. There are three springs, two on the contact bracket one with a ball for the off-on-off detents, you can see just the top end of the springs in the pic, grease springs, ball, the spring wells, helps keep rust at bay. Nice to work in a cake pan, keeps little parts from wandering off.
Note the third switch retaining screw hiding under the two wires inside the control.
Key words; power control over haul fix repair ignition clean
