Pina
76 XS650C, I was toying with the idea of relocating my turn signals over the weekend. I opened up the headlight to see what I was working with. I unplugged the left side to check cable length and all that. In the end I decided to hold on relocating until I upgraded to LED's.
This morning I went to go put everything back together and once I did the left side does not flash. Right side is fine see this video, no flash.
I've checked my connections and they're good.
I looked inside the turn signal switch and did not see any broken connections
if you looked at the video link up top you can see the right side works great and once I switch to the left side you can hear the relay switch on and stay on. Both the front and rear turn signals stay on.
Could the relay have gone bad?
