kjodell10
Will do.Yamalube Yamabond 4 is great to use.
I wanted to follow up, with thanks. Mike's barbless, '78-appropriate manifolds arrived; I marked from the tin holders and the old manifolds, centered and screwed each manifold to a hefty mahogany block on the drill press so I had a reasonable chance of drilling plumb and square; drilled (nothing like sinking a bit into brand-new part!), successfully- I had the ratty old manifold to cut up on the bandsaw, which gave me a better idea of where to hit the aluminum inside the rubber. I was concerned that epoxy might be forced into the barb when I pushed it through the hole in the manifold, so I made a couple of small cones with dowel and a pencil sharpener, pushed them into the open ends of the barbs and removed them with needle-nose pliers when the tubes had been positioned and excess epoxy removed. I'm just waiting for the Yamabond to mount everything; will wait a day so I can re-torque, per advice The gaskets came off easier than expected; there was no gunk between the old gasket and the head. The surfaces on the head are a little discolored, but appear otherwise free of stuff, and smooth to the touch.Yamalube Yamabond 4 is great to use.
If you don't feel like waiting, most auto parts stores carry this stuff. I've rebuilt/repaired hundreds of aircraft engines with it.... not to mention auto and bike engines. It's all I use.I'm just waiting for the Yamabond to mount everything;
Thanks!If you don't feel like waiting, most auto parts stores carry this stuff. I've rebuilt/repaired hundreds of aircraft engines with it.... not to mention auto and bike engines. It's all I use.
I've been looking and can't find a specific torque setting for the machine screws holding the manifold to the flange. Anybody have this information? Thanks.Will do.
It's 6mm. All 6mm fasteners are torqued to 7ft-lbsI've been looking and can't find a specific torque setting for the machine screws holding the manifold to the flange. Anybody have this information? Thanks.
Thanks.It's 6mm. All 6mm fasteners are torqued to 7ft-lbs
Is that pretty standard: 6mm to 7 ft-lbs? Do other machine screws- 8mm,10mm and so on- have a standard torque setting?It's 6mm. All 6mm fasteners are torqued to 7ft-lbs
Thanks; this is such useful stuff.Yes, it's in the Yamaha service manual. Ignore column A. I honestly don't know why they put it there. A 6mm bolt/screw/fastener can have multiple head sizes and still be just a 6mm fastener that want's 7ft-lbs of torque. Pretty silly of 'em.
Remember this applies to un-lubed fasteners... sometimes referred to as "dry torque." Go about 15-20% less if you lube it.
Always look for a specific value for what you're torqueing. If it's not specified, then you go with the "standard" value.
Thank you; I really appreciate the input. There's a certain degree of anxiety involved when you approach a vintage machine from a position of ignorance.You'll actually find a range given for M6 fasteners in some places. It's 5 to 8 ft/lbs. I don't recommend using the max (8 ft/lbs or 96 in/lbs), especially on these old bikes. For many years I used 80 in/lbs but recently I've started backing off on that, down to the low 70's or about 6 ft/lbs. This is partly because I lube all my threads but also to reduce the stress on the threads, especially the ones into alloy. So far, this is working fine for me. The sump plate and right side cover have sealed up just fine using the lower value.
eyeballing the synch process-
How do you tell ? Good question.How do you tell?
I bench sync my carbs before install so they're usually very close.
Yeah, I unbolt the tank, slide it back a hair and block the back up with a piece of wood. Don't need to disconnect the tank and there's plenty of room to slide a stubby in there. More than one way to skin aUnfortunately, Jim's hose trick won't allow access to the screw from the side with the long screwdriver and the tank still in place.
If the left is closed you can only see if the right is further open, not if it's slightly further closed.
