ANLAF
XS650 Guru
Fellers, take a look at the pics. I want to lower the engine. I can change the aluminium brackets, so that's no obstacle. What I want to do is remove the fixing points on the frame that support the bolt through the lower engine. Then I will put them (or new ones) on the underside of the frame.
Can anyone see any reason why I can't do that? I can't see a problem, but it's always better to check with the greater engineering knowledge.
ANLAF
ANLAF
