I'd like to have a gravity knob...
I talk to my tools, whatever I am working on and to myself all the time when I am out in the DCW.
Well, I guess you'll never know then. I was literally amazed at how much easier the centerstand operated after I started pumping those pivots full of grease. My 650 is by far the easiest bike I've ever owned to put up on the stand and the greased pivots are a big part of that. We should consider ourselves lucky. You can't do this to most other bikes. They don't have nice wide stand pivots like the 650 does. And while they work very well if kept lubricated, the down side is they also bind up very well if allowed to dry out and rust, as Mailman has just discovered.
The '77-on post mounted side stand also benefits greatly from a grease fitting, and it's a very simple mod to do. Simply drill a hole in the side, tap it, and screw a fitting in.
Yup, this issue quickly became apparent.I guess I should have mentioned this earlier. The problem I've encountered when trying to put the grease fitting just through the pivot tube is that the fitting usually ends up being a little too long. It sticks into the inside of the pivot tube and rubs on the pivot bolt. So, I put it through the weld where the leg meets the pivot tube. But first I build that weld up a little more with a blob of weld. Then grind a flat spot on it, drill, and tap .....
