flynoe
Hi all
Have a 1975 xs, the mufflers are dented and I would like to switch to either the commando or taper tip mufflers (Mikes) for a shorter exhaust look.
I assume the commando is the quieter of these two choices, I would like a little rumble, not too loud. Will either of these work with my stock head-pipes and still clear the brake attach point, the stock rh pipe is indented to clear this?
Will the mounts on either of these mufflers line up with the factory tabs off of the passenger pegs, or is it a big deal to get the universal mount to fit.
Thanks in advance for the advice. If you are running these and have any pictures.... thanks,
