jd750ace
Front Toward Enemy
A copy of a weak part. How good would you expect it to be?
It's not that they're no good, they're just very weak, even when new. They only produce about 10 or 12K volts. Nice aftermarket coils usually give you 30K volts or more. If everything else is right with your bike, the stock coils will work fine. I ran mine with them for the the first few years I had it. The factory built near half a million of these bikes with them and they all ran. They used the same coils on several other models as well.
If you have any future plans for a Pamco, I would advise you not to waste any money on new stock coils but rather apply that towards the Pamco. I would get the basic kit for about $100 and buy a nice aftermarket coil to go with it. Or one of those used Honda coils guys are starting to use. For about $15, you can't beat them.
Because the don't have you clueing them into all the secrets of the vintage bike world. Let me ask you this, if I buy one of those coils, the higher resistance one I guess, would it work with my pouts until I buy te pamco? Then when I'm ready I can just swap the points and keep that coil?
any of them over 4 ohms will work for me without the resistor though, right? Someone said 4-5 earlier in the thread, so I figure it would be best to be as close to 4 as possible. Or is there no noticeable difference?
5Twins, how long ago was it that you bought that coil for $15? I'm looking now and cant find them for less than 70. I do see the Andrews 4.8ohm for about 50 though. Maybe I'll grab one of them. Then I'll struggle mounting it for a few weeks.
