Jeremiahwsnyder
Hello all,
First off I would like to thank everyone on xs650.com for providing so much great information about these bikes. I have been reading and researching posts the last two weeks and have learned a great deal!!!!!
I just recently bought my first XS650 on CL. Its an 82 special that has been hardtailed. When I bought the bike the PO told me that all that it needed was wired up, seat and tires! I brought it home to PA about two weeks ago and starting reading and researching this forum trying to figure out where I should start. I basically want to get the bike running first then I am planning on doing a complete engine overhaul after riding it some and learning about it's personality. I have many ideas and plans for the bike, but I am at a stand still right now. I have absolutely no electrical knowledge at all and I have been reading and studying all the wire diagrams that has been provided on this site. I would like to see if anyone could give me some advice to what I might be doing wrong. I cannot get the bike to fire up! Not sure if it's due to my electrical skills or possibly something else.
The PO started wiring the bike himself and did not finish. I picked up where he left off. It is a 82 special, kickstart only (PO removed starter solenoid). Here is how I have it wired at this time.
Charging System (Stock)
3 whites from stator connect to 3 whites from combined Rec/Reg
Green runs from rotor to green into Rec/Reg
Yellow is dead ended
Brown runs from rotor to Rec/Reg then connects to red/white from TCI Unit which is then ran to the ignition switch onto ign post.
Orange runs from pickup to white/red into the Reg/Rec
Black runs from pickup to white/black into the Reg/Rec
Gray runs from pickup to white/green into the Reg/Rec
Ignition System (Stock)
orange from ignition coil runs to orange into ignition unit (TCI)
Re/white runs from ignition coil to ignition unit (TCI) then to brown from Rec/Reg then to ignition switch on ign post.
Red runs from Reg/Rec to the battery positive with 20A inline fuse and branches off to ignition switch on battery post.
black runs to battery negative along with black from ignition unit (TCI), then also have another black running from those to engine to ground battery.
Also have a larger black ground from the starter running to the ignition switch on ground post.
With all that said I bought a brand new battery and NGk plugs. I know that I need a fully charged battery from my readings. Here is where I am confused. With the bike wired this way I am able to turn the ignition switch and the bike tries to start. The starter solenoid is not installed should this be happening? I thought I would need the starter solenoid to use the electric start system. Also when I turn it over the wire that runs from the battery to ignition switch battery post gets super hot and started melting?
I am not getting spark consistently either. One minute I am getting it and the next minute I am not. I tested the pickup with VOM and it tested fine reading 734 Ohms and I also tested the Rotor which is reading at 3.4 Ohms so I know that is bad (will that keep bike from starting?) I pulled the carbs off and cleaned everything. I believe the motor is getting fuel, plugs are wet when I pull them out. I am gonna check for compression in the next couple days.
Sorry for so much half ass information and I know from reading this forum that my issues are redundant and I know I'll probably be told to read more and do my research. I have and still am, but I would greatly appreciate if someone with more experience might be able to point me in some kind of direction to get this thing to come alive for me.
Thanks to all
Thanks to all
